Help Disappearing keyboard.
t12b25
Hi everybody .
For some reason anytime I'm typing something with this phone the keyboard just disappears and it takes a while for it to come back. Any idea what causes this?.
Any help would be appreciated.
Thank you,
Anthony.
No not rooted . it's not a memory problem . I'm not sure if it's a ram problem making the processor slow?,
Thanks again,
Anthony
I had a similar problem with the stock lg keyboard before I rooted...except it would randomly delete words or add words...I was told to download the Google keyboard and that worked for me
Well , it seems that not only lg's keyboard is doing it, but the AI type keyboard is disappearing too , so idk what or why .
Thank you,
Anthony.
Do you clean your caches?
SD maid will clean system and clear corpses (pro key allows you to clean app caches).
Any good cache cleaner will clean app caches.
Go to the settings menu of Metro Web to clean all the different internet caches.
Get "Fast Reboot" from the PlayStore. It safely gains more RAM.
Get "Quick System Info" from the PlayStore to monitor your RAM. The higher the free RAM and the lower the idle RAM the better.
Get "App Manager lll" from the PlayStore. Move all apps without an x in the "movable app" section to an external SD card. For further instructions go here: http://androidforums.com/showthread.php?p=6628177
Keep your internal storage above 200MBs if possible.
This should improve things greatly.
