I have been waiting for Gingerbread, and still not able to get it with DX2 - I heard of a work-around to load 2.3 and install Gingerbread! Has any heard of this?
It looks like the 2.3 / GB release for the DX2 is pretty imminent since VZW's released notes about it (http://support.vzw.com/pdf/system_update/droidx2.pdf) and that usually only happens when the roll-out is pretty close.
If you've not done any manual installs/updates before, it might be easier and worth waiting since it will be much simpler and easier to take the OTA (over-the-air) update.
Check out the forum link that lunatic59 kindly provided...I'm sure there's good folks there that will debate the pros and cons of waiting since they know your phone best.
