Sure, but make sure you create a backup of previous build just in case.Can I dirty flash? And thanks again for the new update!! Can't wait to try it!!
Is there a change log for the new buildFinally a new build has been released! Make sure you backup before flashing this one. A lot has changed and may or may not cause issues.
Download: https://www.androidfilehost.com/?fid=24052804347808369
Builds are also officially split. It will still work on h345 but new TWRP build for h345 as well as CM is on the way.
Delete it from system/framework via recovery I'll check on it later if someone could pull a log.Just flashed the rom on my h345 and it says the following, "Unfortunately, com.quininc.cne.CNEService has stopped."
When I press ok, the box appears again.
Will this completely make it go away? I tried uninstalling the app via titanium backup, to no avail, so I just went back to last cm version. And thanks for quick replyDelete it from system/framework via recovery I'll check on it later if someone could pull a log.
Yes, the framework was crashing and not the CNE app.Will this completely make it go away? I tried uninstalling the app via titanium backup, to no avail, so I just went back to last cm version. And thanks for quick reply
Alright let's completely remove cneI went to system\frameworks and moved com.quininc.cne.jar to my sd card and that did not solve the problem. I will keep trying different stuff to see if I can find some temporary fix. Also, the camera looks like it works. I opened the app and I could see what the camera was seeing. I haven't tried changing to camcorder because its hard with the constant prompt that cne is not working.
Any other issues to report?Deleted the files and now the box does not appear
Thanks
Wait on the next build or delete the files for CNE. I posted a list on page 20 of the related files.keep getting this error "Unfourtunately com.quicinc.cne.CNEService has stopped"
Thanks man, couldn't find the files at first, but mounted the system and sure enough there they were, thanks again man, and just thanks everyone for the questions, help, and replies, ur all awesome!!Wait on the next build or delete the files for CNE. I posted a list on page 20 of the related files.
LogcatSo uhh...video playback. Only app that does work right is YouTube. Streaming media in native video player doesn't work and playing back video from storage...that's an experience! Audio is slowed down and out of sync with video causing skipping. Thought I was the devil talking to my son! Lmao. Plz fix?
Yeah, it's been there for the past few builds.@Noobified Did you merge your newest kernel build with the newest rom build? Or will I need to flash separately?
