Help dispaly automatically wake up
Some apps and notifications can turn on the screen (or so I have observed) so perhaps you have installed a buggy app. If you have not spent a lot of time customising so far, I would recommend a factory reset to see if this cleans up the problem. If it does then re-introduce your apps one after the other until you find the culprit.
Hope this helps...
Regards,
Eric Ritchie.
Hope this helps...
Regards,
Eric Ritchie.
Factory reset will turn the phone without root so my root will die!
+ all my apps and data will wipe out!
and i want to inform you when i update today 15 apps the problem occur
