Help Display area
Nitix
Hello,
I went through one thread that matched my query but was a bit different, so here goes...
I noticed that the display on my screen is a bit to the left. I can see a bigger gap between the display and the black color that is inside the glass on the front panel on the right-hand side. Not sure if this was there from the beginning.
Anybody hear anything similar? Thanks.
Yes, ages ago, but I can't find the thread, nor can I recall if there was any resolution :o.
How noticeable is it? Do you have to strain to see it, or would you notice it straight away?
