I have my Galaxy S II on the table with the display turned off and with the pattern lock on, and suddenly the display turns on and I check the status bar for any notifications and there is nothing. I go to the task manager and close all the active apps and still it does so for no reason at all. I terribly need a solution because it reduces the standby time of the mobile. Also I just can't ignore the fact that its happening. So if you have any ideas of stopping this and if you guys out there actually know what is wrong, please reply. I really appreciate it. Thanks in advance
