Help Display killing battery?
Ringhale
Okay I do not have the update installed yet Battery is at 30% and I'm at 19hrs unplugged but with Very light usage ( I was sleeping for about 7 of these hours) Battery use says Display 68% I have the display set to lowest brightness 24% cell standby and 8% Phone Idle my signal is usually around -95dbm does this seem alright or is something odd going on seems like 68% for the display on the lowest setting is a bit much.
BTW GPS is on, sync is on, wifi has been on but very little, no bluetooth
Sorry if this sounds as I'm complaining about my battery life it just seem like 68% for the screen is a lot...
