Help Display on when receiving call or text
Marc1969
Member
I've been searching this forum for about an hour now, but somehow my little problem has not been answered. Or nobody asked the same question, which would be more logical as I think that the answer is probably very easy...
When I receive a call or text the display does not turn on. I first have to press the home buton to see who is calling me. I can't remember if that has always been like this or that it has happened after I installed Checkrom or something else...
Weird, mine turns on for calls, and i think it doea also for sms.
Im on checrom too and i dont think it should change it, but i dont have an answer..
Definitely turn on for calls. Else how you answer?
For sms, lockscreen comes on and notification/sms scrolls along the top. Works that way in stock. Works sometimes with GoSMS :rolleyes:
You get the picture.
The screen should definitely turn on when you receive calls. Did you do a full wipe before flashing checkrom? If you didn't I would reflash but do a full wipe this time.
@Shotgun84: I didn't do a full wipe before flashing. But not for the first time... Did a full wipe this morning, now all as it should be :D
Thnx!!
