Five hours ago, my phone wasn't charging correctly.(I've had to add paper to the battery compartment to hold the battery in place) My Dad(who works with electronics) decided to clean the charging port. So he sprayed electronic cleaner directly into the port. Then used cutips cleaned it. It fixed the charging problem, but when I turned my phone back on, I noticed almost immediately that the lcd display on the phone was wrong. It is darker than it should be for most of the phone, and there are bubbles within the display of correct brightness. I have played with the brightness, tried using a hairdryer to dry it, and neither worked. Wondering what I should do. The water damage sticker was bright red and soaked. Help please
