Is there a Widget to quickly increase brightness when you are outside with the push of a button if you are using the manual setting?
There is a widget, long press on the screen then Widget>Settings>Screen Brightness
Try pressing the widget then go into settings and adjust the slider, just be sure the auto brightness box is not checked.
I don't know about you, but I can't get to the settings dialog through the widget.
