I received comments at the Juice Defender forum from the app's devs suggesting to try turning off Juice Defender and see if the problem recurs (duh!!...good idea, huh??) So I turned off JD, and the problem STILL happened.
So, it does NOT seem that the problem was caused by JD (though still ODDLY coincidental that I NEVER had this problem until trying JD but...). So I followed up and asked for names of apps that might be conflicting/controlling my screen display timeout settings. I then got a reply that there were "too many apps to list that might cause this problem"
I was a bit confused by this reply.
My original thought with the screen timeout issue being caused by Juice Defender was because there is a SPECIFIC SETTING related to that screen timeout. I know that various apps can, perhaps, affect a phone sleeping or can keep a phone "on" for its purposes but the problem I was having was VERY specific...with NOTHING running other than what I have been using for months, my phone now ha the screen turn of PRECISELY after 15 seconds of being on. It is not a random occurrence...and not for a random time. If I "power on" my screen on my EVO then PRECISELY 15 seconds, my screen shuts OFF. It is AS IF my screen timeout setting IS for 15 seconds but, like I mentioned, it is not set for that interval.
Because my issue is SO PRECISE and specific...a recurring timeout for EXACTLY 15 seconds....THAT was why I was wondering if anyone else could comment on what might be causing this. Perhaps my best bet is if someone reading this has had this happen or knows someone who has had this happen. I was therefore wondering if there were any apps NOTORIOUS for causing this type of screen timeout conflict (and with such repeated precision)
I guess I am a bit confused and surprised at the comment about "so many apps" that could cause this problem because, in my short experience with the phone, yet a decent knowledge of many of my apps settings, I cannot quite come up with the name of an app that I could remember settings and preference options and say "yes, I can see that app might affect my screen timeout." THAT is why I was hoping for some app suggestions to look at. Can anyone provide one or two examples of such apps and WHY they would affect screen timeout?? Like I said, I just CANNOT quite think of one that might because I have never seen an explicit setting option that might affect it.
THANKS!!
