I've been wondering this as well. Hopefully someone can shed some light once they get a hold of the device.
It's glass.
Motorola Triumph, Sexy And Elegant ready on July 21 - Verizon Cell Phones[/Q
where did you find this info?
I don't think thats accurate. I'm pretty sure its plastic.
Out of curiosity, is there really a huge difference between glass and plastic screens? I've had numerous PDA's and smartphones, from Palms to Axims and from Treos to Blackberries (both touch screen and non-touch screen). I'm sure not all of them had glass screens, but I never had an issue with any of my screens.
So, is the concern scratch resistance or performance, or both? I've always been anal about using screen protectors, so my screens have always looked brand new even after a couple years of usage. And, actually, the only performance problems I ever experienced were attributed to low quality (too thick) screen protectors.
Also, aren't there pros and cons to both types? I.e.: plastic would be more prone to scratching, but glass would be more prone to cracking? I'm just wondering what the concerns are.
Thanks.
This is my understanding. Glass is glossier, hard to scratch, and easier to crack. Plastic is somewhat matte, easier to scratch but almost impossible to crack.
I personally wouldn't go with a screen protector, especially if using a glass screen. Not sure if you've used phone with a glass screen (like iPhone or iPod Touch), but they extremely hard to scratch. On the other hand, one drop could completely shatter your phone.
Unless you keep your phone face down on the table or in your pocket with keys and coin, it'll look brand new after extended use as well. I normally keep my cell phone in a separate pocket from keys and coins.
T
Thanks.
