So I received a new digitizer from repairuniverse:
Some questions b/c I installed it and it's not working right.
*Do I need to remove all of left over adhesive where the LCD housing is?
*Do I need to remove the clear cover on the back side of the digitizer which will touch the actual LCD?
*How do I get the Digitizer to stick to the LCD?
When I originally put it back together it all worked except the bottom buttons:
Home, Menu, back etc.
Thoughts?
Thoughts?
