Ok, so I saw this xda thread here:
[EB01 WALKTHROUGHS] Rooting, Clockwork, Voodoo, Stock and Custom ROM, Battery, etc - xda-developers
I guess everything I need can be found in there, but I have a few questions before I begin. For the record, I'm on DL09, running a DL09 compatible Nitsuj Nextang theme. Never installed Voodoo. Have been running the same version of CWM since maybe before DJ05 was released?
Ok, so my biggest question is regarding all the CWMs I see on that thread. First of all, I think I'm finally ready to install Voodoo, so should I ignore post 4 altogether? If I were to deal with post 4, I have two concerns: one is that the link in part 1 for the link to the zip file is dead. Is that file supposed to be "update.zip" which it mentions in method A (I already have an old update.zip file on my phone for CWM, do I need a new update.zip for Froyo?), or is it supposed to be "cwm_froyo.zip" which I see in method B?
I wanted to use Nitsuj's Nextang theme for EB01. Should I just get that file and use it the same as any other zipped Froyo ROM in Part 5?
In part 6, I'm a little confused. Say I want to install Voodoo. Do I just start with post 6 after I've done everything else? I don't see any mention there of red CWM, how does that fit into all of this? When you have Voodoo do you have both red and green CWM to boot into?
Thank you!
Thank you!
