Let me say how much I really appreciate you helping me in this very frustrating time. I found out late last night how to fix my issue. People have this crazy thought that if your on 4.4.2 kit Kat that you have to wait for that particular ruu to be released. Well I assume if your not s-off that may be the case. But if your s-off you can fix this horrible issue.
What I did step by step:
1. download 3.06 HBOOT:
PL83IMG - 3.06 hboot
2. Rename stock hboot file to : PL83IMG.zip and place in the folder that contains your fastboot.exe file (On your computer)
3. Flash hboot
Code:
Step 1) adb reboot bootloader
Step 2) fastboot oem rebootRUU
Step 3) CD to directory containing hboot zip (i.e. cd C:\sdk\)
Step 4) fastboot flash zip PL83IMG.zip
*** When it says it is done in the terminal/cmdprompt execute the following ***
[The green bar only fills up about 75% of the way]
Step 5) fastboot reboot-bootloader
Then you can either do this one or two ways:
1st way:
Let me Flashing the Stock Splash Image
1. Download the stock splash image
Dev-Host - [HTC]_StockBeats_splash1.img - The Ultimate Free File Hosting / File Sharing Service
2. Rename file to splash1.img
3. Place the file in the same folder you have adb.exe and fastboot.exe located.
4. Plug in your phone to a USB port, turn on USB debugging and open a command prompt. cd to the directory your adb/fastboot is located
5. Run the following:
Code:
adb devices (your device ID should be displayed)
Once in the bootloader, run:
Code:
fastboot flash splash1 splash1.img
Once complete, reboot the phone using the menu or
Code:
Or just run the ruu after the hboot flash.......
