Root Do any custom ROMs NOT break something.
Aaron91RS
Member
Every ROM out there seems to breaks something whether it be the camera or 4g or bluetooth or something else. Even the stock rooted ROM has a disclaimer to flash a new custom rom because the rooted stock one isn't perfect.
Is this just an android thing in general that all these custom ROMs have certain tradeoffs where something gets messed up?
*I'm sure I'll get reply from someone saying I have ____ rom and it's great, but you have to realize you can pull up threads where 10 other people have issues using it.
I have been running the Fresh rom since .2, I am now running .5.3. I haven't experienced any issues but I always do a wipe before flashing a custom rom.
In the newest version of Fresh, everything works.
The only thing that was having a slight issue with .5.3 is Qik, but I think that has been resolved, and if not, it will be soon.
Here's a list of the reported bugs for Fresh.
View Issues - MantisBT
As you can see, all reported bugs except the Qik one have been fixed.
In many instances, issues pop up from users failing to follow the dev's directions correctly as such as , not updating radio, not completely wiping before flash etc.
OK some newbie questions
Does fresh 5.3 keep senseUI?
If I just took the EVO out of the box do I need to do a backup since I have nothing of my settings on the phone to lose
Do I need to do a wipe on an EVO just out of the box.
What happens if you do the wipe correctly, then restore a titanium backup? I backup my apps + system settings since I want to retain my SMS and call log, etc. Does restoring this affect the things that doing a data wipe is supposed to clear up?
No, you'll be good. I've been using Fresh since 0.3 and I've had zero issues with that or the new release. They are the most complete Roms out there. Smooth as silk, like it came from the factory that way.
Yes it keeps sense... I'm not sure about the wipe
You should do a nand backup before you flash any rom just in case something goes wrong and you need to restore
EXACTLY!
I've been running custom roms on phones for years and whenever somebody has a problem, it almost always boils down to them trying to skip a step or not follow the directions.
