Do I have a battery or phone problem?
jeffrj4au
Member
I purchased my samsung galaxy S3 just 12 days ago. I had the white phone at first and after having it for 4 days, I decided to trade it for the blue. The white phone absolutely had no battery issue, but this blue phone has been a different story. This past weekend the battery drained from 100% to 63% overnight while the phone was asleep. I did a factory restore and that seem to make the battery better, but still not as good as should be. Since then, I've recharged the phone to 100% before I go to bed and the past two mornings, the battery has drained 13% and 15% while asleep. Also, on those nights, I removed all running apps, turned off wifi and turned off the GPS, so I've done everything I know to do.
I think I have an issue, but what do some of you think?
Absolutely you have an issue.
Can you take a screenshot of the power graph found in your settings screen?
I'm at work and they block you from going to websites that host pics. I can give you the details on the graph.
The top of the graph says 2h 10m 57s battery.
Screen 56% (I've turned the brightness down a lot)
Cell Standby 19%
Android OS 7%
Android System 6%
Media Server 4%
Maps 4%
Device Idle 2%
Picsart 2%
Gallery 2%
It's went from 100% about an hour ago to 86% with minimal usage.
If you tap on the graph it'll make it bigger and give a few more details. Does your awake bar at the bottom match the screen on bar or is awake a solid line?
First off, the color of a device has zero effect on battery consumption or even the with the operation of the device for that matter. It seems that it might be a problem with a rogue or incompatible installed app. Sometimes even after a reset, we reinstall the application that would cause problems like this.
Try this: Perform another 'reset' on the device - this time only reinstall the preinstalled applications (the ones that came pre-installed). Do not mess with any of the factory settings (what most users don't understand is that these settings was preset for a reason - so just leave as is).
Note: Even though we might not be using the device - it still uses battery power over a period of time. It's normal to see a drop of battery percent even though the device isn't being used. However, seeing a huge amount of battery consumption (something that just doesn't seem normal) being used might be a hint that something is draining the battery way more than normal.
If the problem seems to be getting worse -- take the device into your nearest repair center for a diagnostic test. Chances are you just might have a defective phone.
Best of luck.
Cell Standby 19%
Android OS 7%
Android System 6%
Media Server 4%
Maps 4%
Device Idle 2%
Picsart 2%
Gallery 2%
That looks pretty normal. The screen SHOULD be your biggest battery hog. With my GS3, I get about 3.5 hours of active screen time on a good day. Generally, it's 1% of battery life for every 2 minutes of screen use.
Best of luck.
Sorry but I chuckled when you made the comment about the color, I probably should have made myself more clearer. I realize the color has no effect on the battery. I was just letting you know that I had another phone and that battery seemed fine, while this one seems to have issues.
Best of luck.
I know how to reset my phone to factory settings, but how I do I do a reset you're talking about.
After a factory reset I always do a battery calibration. You charge to full then reset battery stats and then use as usual but make sure you fully drain the battery. Then do a full charge without interruption.
But as Rush said.. If the reset or my suggestion doesn't work then you should go and have it looked at.
doing a battery 'calibration' is bad for Lithium Ion batteries and draining one fully is bad for their lifespan. Li-Ion batteries are not designed to drop below 25% charge on a regular basis, at all. a battery calibration has been obsolete since cells stopped using Ni-Cd and NiMH batteries.
Factory reset:
Settings-->Privacy-->Factory Data Reset
Its not calibrating the battery. Its to get the phone to recognize the battery's life span and charge limit. The amount allowed is use.
Unless I am wrong and I am willing to admit that if someone can show me but this has worked on 6 phones I have personally done it on without destroying the battery.
i know that doing that to any Li-Ion will significantly reduce their useful life. you won't notice it right away but a couple of years later you will. had that happen to an iPhone and a laptop both using Li-Ions. i have not yet seen any Android with the problem of innaccurate battery meters; last phone with the need to calibrate was a Nokia 5190i, which i used until the battery refused to stay on the phone (lol) and i knew the battery meter was off when it went from 75% to dead instantly. but it used a NiMH battery too.
How many people keep their phone for many years..?
I understand your point though and I'm not discredititng you in the least and I hope you don't take it that way at all. I just feel right now that would be the best option aside from turning the phone back in to replace it.
i was very happy with the Nokia 5100-series. durable, easy to find parts for, and good at making/receiving calls and always got a strong signal. at the time i was not into browsing the web or apps on phones. i was a bit of a late adopter, probably a good thing (although i started with Android with the horrid Eclair). but i digress, suffice it to say that unlike iDevices, most if not all Android phones (not so much tablets though) seem to have replaceable batteries.
