joshua.worth
Just wondering as I've had many devices without SD Cards that I could flash and back up and yada yada just fine. Maybe it has something top do with the partitioning.
Lol, you can flash ROMs from the internal memory just fine...
Yes indeed the riddle has been solved
Infact the navigation starts in the internal storage.
So if your zip is on your internal storage simply use the recovery app to reboot into recovery
Whether you are restoring or flashing a zip you will begin your navations in the internal storage area.
Ok ,so maybe the problem has nothing to with an sdcard but gettin the app to work
I am assuming you can at least get the app to open
You then click the top button
2nd init recovery
Then wait a second for a box to pop up saying
Success
You then click reboot recovery
Your phone will then reboot normally
As opposed to rebooting into recovery
If this the case i am not sure what the issue is
I installed mine the only way described in the instuctions.
It took me a,minute to realize you had to click both buttons on the recovery app
I did those buttons presses but there is no way described other than the words "install" nothing about where to install whether as a system app via root explorer or as any old app simply by clicking on the apk file and she selecting install from the toast notification.
SuperSU prompt was granted?
