Root Do I need SetCPU anymore?
PatHoge
Hello all,
I've been running UD1.0.0 for a while now and I'm curious about this. Since UD has the CPU governor and speed settings, what happens if I change the speeds using SetCPU? Does one take precedence over the other? Thanks in advance for the help!
Remember that Ultimate Droid comes with a CPU governor, but other ROMs may not. I use SetCPU because it works across all ROMs and kernels. I disabled the UD governor because I didn't want any CPU conflicts.
Okay, thanks for the answers. I guess I'll just disable the UD governor so as to not cause any confusion.
