swindelljd
Member
So my Dinc burned up it's battery today because it wasn't playing nicely with our office wifi router. It basically spent the whole day trying to connect, failing, scanning, trying to connect... you get the idea.
So just before I left it ran out of juice and shut down. When I got into my car, I did my normal routine which is plug it into the car charger and then turn it on to listen to my podcasts on my drive home. Except that I forgot it had run out of juice so when it booted it stopped at the "eye of Sauron" for a long time. When I say a long time I mean as long as if it were reinstalling Froyo long.
When it finally came up, pretty much anything that loads a process at boot that wasn't installed on the system partition (eg Skype) did a FC as soon as I got past the lock screen. Thinks like Google Finance, SportsTap, Mail, etc crashed at boot. And anything I opened including Google Market immediately show me the TOS screen as if it's the first time I've launched the app. However most things once I pass the TOS screen will immediately FC. It seems like the internal cache/system partition was corrupted during the loss of power shutdown or the subsequent restart.
Since I've tried a clean shut down, 4 or 5 times, I know that this won't solve problem.
So my questions are:
1) has anyone else experienced this kind of failure and how did you solve it
2) Should I use the factory reset option on the phone and then upgrade to Froyo with the update.zip(s) I have handy or go straight to the Froyo RUU that's floating around.
3) Is there any way to recover WITHOUT a factory reset of some sort? I expect this is a NO but thought I'd ask
4) Should I expect a factory reset to fix the phone or is it basically bricked at this point and I need to call VZW (my last resort)
Please let me know what you think.
thanks,
John
thanks,
John
