Root Do I use D2 Bootstrapper for .602?
banzai75x
I am on .602 SBF rooted. Do I use D2 Bootstrapper or ROM Manager 2nd Init?
I'm asking because last time I didn't ask and then hosed my phone and had to start all over again.
I'm assuming I use either D2 Bootstrapper or ROM Manager (not 2nd init) but wanted to make sure.
You only use Rom manager with 2nd init recovery with a 2nd init Rom. If you are on .602 then you would use either Rom manager with the droid x recovery or D2 bootstrap.
You are probably best using D2 bootstrap because .602 is having problems with Rom Manager. Personally I would sbf the phone and go with rooted .596.
