MotoTriumphant
As stated in title you will brick urself.
Umm I guess not ur one of the lucky ones lol
But seriously no one should delete these two things you have been warned!
If you still want to delete those apps after reading the replies... don't. You never know. I heard people messing up their Optimus' M by doing it, it might as well mess up your phone.
Without mymetro on stock optimus m, you get internet connection problems.....doesn't happen on custom roms though.
The webrowser is also a cause to the random reboots a lot of the OMs had.....
I got rid of myMetro on my stock Optimus M and I never had internet connection problems.
Strange...I got problems.
Soo can someone clear this up, can i delete the Mymetro.apk from system/app on the MOTION..?
Man.....some people don't read![]()
Lol :-D seriously though, it's ok to delete it. I deleted it the same night I rooted (same night the root method was found to work) and my motion has survived tons of reboots. My bricks were of my own doing.![]()
My Motion gives me the option to disable the built in apps, i disabled Metroweb, Appstore, Metro Block It,, i haven't had any problems, when you click on disable you do get this message.."If you disable a built-in app, you cannot see this app in the phone and an unexpected error may occur in other apps".
Well im not sure what they mean by you cannot see this app in the phone cause i can still see it in app info and can still enable it.
Ive got software version MS77010c, is that the same as firmware version?
