is running the computer update but i see the phone little more fast and responsive and the battery duration very wellDid it atleast fix the phone,?
pc handset update tool...
i found this out by accident, I was just attempting to unroot/factory reset, start fresh, for the hell of it, and saw it was 08c instead of 08b, not thinking anything of it i continued. ;\
Reflash stock recovery. ZTE Warp Recovery Installer V2.zip use that and choose the stock_recovery.bat file. Then you will be able to use FTM mode again.I can't even get the handset to work now at all, cuz it says This now, and I don't know what to do now. and my phone wont go into FTM mode anyway anymore.
"Special case: U880 does not require access to FTM mode, and you can connect the phone to pc directly"
Does anyone know what to do to get back into FTM mode instead of CWM
Can you update on how the phone is doing since the update I really don't want to lose root but this phone has given me so many problems that I didn't have the last few days that I'm willing to give up root for a stable phone
Running b08c here. Rooted by woodstck77's tutitorial, phone is running fanstatic. I also added the lines of code from the modified build.prop on the warp forum (i did not replace ghe entire build.prop file! I just cut and pasted the lines of code as the new build.prop is way different and i wanna go through and examine it)
Thanks to woodstock77, for an old guy yous got skillz!![]()
would you be up for uploading your build.prop for those of us who are too lazy/noob to try it on our own?, maybe on the original build prop thread?
I am at work now but will upload both when i get home at 6pm central time.
Oh sorry, give me a few and ill upload it as soon as my boss is off the pc.
...guessing you have this solved however if you dont:
I was on CWM and used the online tool @ ZTEusa and it put me to b08c stock FTM was restored. I then installed using snake X's one click deal, then the Superuser.zip from woodstock.
I have over 260+ apps no reboots yet.. seems to be a lot more stable.
