rudybow
I think I'm going to need the extended battery. The stock does alright, in about 11 hours I had 20% left and that was with some heavy usage. I use my media player a lot at work to play songs though and I'm not sure how much that will drain it down.
I found these deals on the extended battery and cover, from different places though. Do these look legit and worth the risk? That would be around $46 for both from these places, against $60+ at the trusted Amazon. What do you think guys/gals?
Motorola OEM Battery BH6X 1800mAh SNN5880 -TheCellGuru.com
Amazon.com: OEM Motorola Extended Battery Cover Door for Motorola DROID X, SJHN0449A: Electronics
