Dock + extra battery slot?
GNS1310
I have a spare battery just sitting around, I'd like to keep it charged. Looking at some docks on Amazon, they get 3 stars with numerous complaints about the phone not fitting quite well, or not connecting, not charging etc...
Not looking to spend too much, but I do like the idea of setting the phone in a dock with the spare battery along with it sitting neatly on my desk.
Suggestions?
Suggestions?
I don't know about a dock, never had much luck with them with ANY device even back to my Dell Axim, Toshiba e740, or Casio Cassiopeia PDA's (dang, sometimes I miss those) BUT you can get a cheap (under $5) stand alone charger for the Rezound on Amazon, just about any that are compatible with the Rezound, Thunderbolt, MyTouch 4G, Incredible HD, or Merge will work fine. Here are some examples:
Amazon.com: eForCity Battery Desktop Charger with USB Output for HTC ThunderBolt 4G / Incredible HD: Cell Phones & Accessories
Amazon.com: HTC Rezound 4G Battery Charger(Compatible with HTC Thunderbolt, Merge, Mytouch 4G)+ Exclusive Black And Green Color Key Chain Kit: Cell Phones & Accessories
I bought this one: Amazon.com: RND Power Solutions Deluxe 2nd Battery Charger and Data Sync Cradle / Desktop Dock Station for HTC Rezound (compatible with or without a case): Cell Phones & Accessories
It works pretty good. The screen doesn't rotate when docked though. But there are some ways to work around that: download a clock app, manually start dock mode through the clock widget, etc.
Secondary launchers solve the rotation issue. I'm using Apex (free version, stock phone) -- has settings for: always rotate, never rotate, portrait only, landscape only -- this allows you to use your phone when docked. If you just want a big clock, you could always have a screen running a large clock app and slide to that screen when docked.
