Dock replacement
matttye
Android Expert
I've just gone back to HTC Sense UI from Launcher Pro as LP was killing my battery for some reason; it has more than doubled since going back to Sense!
The main thing I miss from LP is the dock, is there a way I can replace the dock without the entire homescreen on Sense? I've searched for apps on the market to no avail :(
when using Launcer Pro, did you remove all widgets from the sense ui before hand?
I found once i did this the phone was quicker and used less battery as the widgets arent updating in the background behind LP
