I've tried everythin I can think of to rectify it from different Roms to running hawkers nuke script, also deleting and installing it but I always get the same battery drain which is quite excessive. the culprit seems to be mobi.mgeek.tunnybrowser
here are some screens
The stats from above are actually quite tame compared to usual. It's quite often using 45 + of my cpu and usually has a higher battery usage than the display.
Can anyone offer a fix. I don't want to delete it as i find dolphin by far the best browser and I've tried most other ones.
