Successfully decompiled and re-complied framework-res this morning.
What version of apk multi-tool are you using? I'm on 1.0.1.0.
Did you install framework and systemui files first using the setup script?
Well i don't think so haha...how exactly did you set it up? And yes i believe that is the version that I'm using... I just downloaded it straight from the apk-multi tool website. Please share how to set this thing up if you don't mind Sir
Ok i'm assuming you have deodexed framework-res and systemui?
1 - Copy the systemui.apk and framework-res.apk into the folder named "other" inside your multi-tool folder.
2 - Double click the setup.bat file and a command window will appear giving you various options. Go for option 2 (install framework-res files)
3 - You should then see a list of more options. Go for option 1 (install framework-res)
4 - Repeat step 2 then select option 4 (install systemui)
Now you are ready to decompile. Using script.bat switch to decompile mode (option 26). Then decompile using option 9. Re-compile using option 11.
ok i got everything set up and it worked the way you said it would...just one problem. Switching the decompile mode isnt allowing me to access the file that i need lol. And if you dont change it it errors out. Im trying to get into the framework-res/res/values folder annnnndddd its not there lol
