the hulk
I will shortly be in possession of one and I will be using it on T-mobile/Metro PCS, is there anything in specific that I have to do to get LTE coverage? I know both models T-mobile and ATT both have band 4 built in, but I wasn't sure if they were any settings that needed modification in order for it to work. The reason I ask is because you had to do some small things for the ATT Note 2 to get T-mobile LTE, so wasn't sure if it was the same thing.
Thanks
Thanks
