Help Does anyone know how to make the noise stop when I type??
jodim
I received the S4 for Mother's day and I love it. However, I cannot figure out how to make the noise stop as I am typing. Can anyone direct me as to how to do this?? Thank you!
Go into settings, then My device, then Sound. Look under System and you can check/uncheck what you want.
Go to the settings on the keyboard your using, under my device, language and input the wee wheel at the side of what ever I've you have set to default, there is an option in there for key press etc :-)
Have we established if these "noises" are the ones inside your head?
Just kidding, I couldnt resist.
My Device-> Language and Input-> Samsung Keyboard Settings (tap the little gear icon)-> Advanced-> Uncheck "Key-tap sound"
After I posted my reply I just saw this one, my bad.
