Well is LED on the A2 active by default, because it doesnt work on the A2 I have. It is right out of the box and it doesnt do anything either for messages or calls. No screen protector on it.
Well I called 611, and they were no help. The AT& T rep was reading off a que card or so it sounded like. He refered me back to Motorola. Motorola refered me back to AT&T and I went full circle. The store where I bought the thing wont exchange it they claim its a face sensor and not a LED light. LightFlow doesnt work on it so I'm stuck with a high end phone that doesnt have all the stuff working. On a good note its has great reception and screen looks great.
I now have an Atrix 2 with a working LED message light, thats for all the advise. Everything else is working great on it also.
It was a new one and everything is working great.Did you get a new phone or was it a software tweak?
In the Motorola manual, it is called a "Message Light". I believe I've seen it flash green and red. I don't know if other colors are available. But so far, I think it only worked with their proprietary email app, as I cannot verify that it works with K9 or even the stock Gmail app (Funny they give you two stock email apps).
Even Better.I didn't have to root my phone to use Light Flow.
This is very true, out of the box. However, if you use other apps, like K-9, they won't trigger the LED.The LED notification, if working properly, should flash for a few different notifications on your Atrix 2 with out any app triggering it.
Green - Emails (Gmail and Other), Messages - text or vm, and missed calls
Red - battery almost dead
Orange - battery low indicator
There are a few apps out there that allow you to customize the LED color to your liking. Handsent (text messaging app) allows you to change to color for texts only.
