J jaliy Android Expert Sep 2, 2012 #1 after factory reset there's preloaded widgets like clock and weather, 3 pages of them. is it better to remove all of those so battery drain slower?
Metroid Prime Oil Can!!! Oil Can!!! Sep 2, 2012 #2 Hi jaliy. I think less widgets = less battery drain and more on screen widgets = more battery drain.
J jaliy Android Expert Sep 2, 2012 #3 Metroid prime said: Hi jaliy. I think less widgets = less battery drain and more on screen widgets = more battery drain. Click to expand... even the preloaded widgets?
C colmmcgrath Well-Known Member Sep 3, 2012 #4 If the widgets access the Wi-Fi, then the battery will be more consumed by the widgets.
