romeodakins
Member
Does droid bionic support gsm or have sim card slot? Can I just pop in a prepaid tmobile sim card with like 100 minutes in it and use that?
It's not that simple. There is a SIM slot, but you can't use the phone on a GSM network without modifying it. Check the root section for details.
Do I have to root the entire phone just for this one thing??? I have a tmobile sim card I've been using on my other tmobile prepaid phone and the sim card has like 500 minutes. So I can't take out the sim card and just put it in the bionic? Can you link me to how to make it work with my tmobile sim card?
>:O I thought it could connect to gsm. I should've got the photon.
It doesn't work well on T-mobile. When it does, which is rare, you only get Edge. Works well on ATT bands though. Doesn't require root.
