Help Does Fontomizer work with SG2?
EveR-1
Hi
Installed Fontomizer app from Market - have managed to download some fonts, but how to install so can use fonts?
Anyone figured this out? Thanks.
Thanks - Have already tried this and it's not showing the downloaded fonts.
Does anyone know how to install new fonts on the SG2?
Have you tried double checking MY apps in the market to make sure it downloaded correctly? I know this sounds obvious but you never know :) . Just covering bases.
Scratch that, I see you have downloaded via a client so gonna take a look .
Couldn't find fontimizer in the market for some reason :S . Which may answer your question, if the dev removed the app from the store. Id look for alternatives for now.
EDIT once more as It seems Fontimizer is called Fonts for Galaxy. Not sure if this has changed recently but a link to http://www.androlib.com/android.application.com-hongik-fontomizersp-pwjnq.aspx confirmed the name change .
With other font packs in the store Ive merely downloaded the app and the fonts appear automatically within the display settings.
Hi! I know this might be a little too late.. But I believe you have to manually install the fonts to your device. To do it, make sure you tick UNKNOWN SOURCES under Settings>Applications... Then, use a file manager to look for the folder where the APKs are stored. Once installed, you can change your system fonts the usual way. Have a happy day! ^_~
