Hi,
I'm one of the Sky Map devs. No, using the app should not incur charges: at present it stores all of its data internally and does not at access the internet.
John
You need to calibrate your compass.John,
Since you're one of the developers, what's up with it being about 20 - 30 degrees off? I point it near the moon and it doesn't show up. Have to move it a significant amount to have it show the Moon. Same thing with Jupiter. Also have noticed it's off for constellations and not planets.
I'm an astronomer, so I do know my way around the sky.
Hellp John,Hi,
John
