Does GPS drain the battery if not being actively used?
JohnJSal
Android Expert
I noticed when I have GPS on but am not in an app that uses it, there is no GPS icon in the status bar. When I go into Google Maps, for example, then the icon appears.
Does this mean that when it's not being actively used, it isn't really "working" and thus not draining the battery, or at least not by much?
If an application isn't requesting it, it's not running. If an application requests it, it's running. It's not like this on the Epic, only the Evo. With the Epic, you have to turn it off, other wise it's constantly trying to work. Keyword, trying. *zing*
Yes I never turn mine off which has worked our nicely. I've lost my phone twice and both times was able to locate it with mylookout. On a sidenote the GPS in this phone is awesome. Mylookout located my phone accurate to within 10 meters both times and both times my phone was indoors.
I used to keep mine off until i needed it but for that past few months it's on all the time and I notice no difference in battery life.
Yeah, that's what I just started doing, and so far it doesn't seem to be a problem.
this is great never knew that, going to keep mine on all the time now too so i dont have to wait to use it like i used to
