HTC Wildfire has 384 MB of RAM and 512 MB of ROM.
Mine came with a 2 GB Micro SDCard from Virgin mobile but can take upto a 32gb I think.
The only problem i have found id that the phone is unable to move apps to the sd cardmeaning limited space, that is untill the froyo update which is said to allow you to move them over freely.
If I'm not mistanken you can download an app, which enables the transferring of apps to the sd card. I had it on my Tattoo, surely you can get it for Wildfire too. Only problem is, a lot of apps dont run from the sd card,
