Help Does it Open in your Pocket?
anduril66
If you carry the Milestone in your pocket without a case, do the keyboard slide out? If so, is this bad for the phone and doest it pocket-type?
It takes a fare bit of pressure in the right directions so I don't think it would slide significantly in your pocket. As for breaking the phone it seem like you would have to smack it pretty hard against something, so you should be safe unless you routinely keep it in your pants pocket and hip check your car door closed. Pocket typing does not seem to be an issue either.
The keyboard is fairly tight when in. I haven't had any issues with it opening in my jeans' front pocket, and that's where it is most of the time.
Sent from my Milestone
Mine does open slightly when it's in my trouser pocket sometimes. There doesn't seem to be any negative effects from this, and because the keyboard requires a firm press I think there is very little chance of "pocket typing".
