Help Does my tablet have a built in calendar
dr4sight
Hi,
I have two Android devices, an Optimus V phone and Samsung Galaxy Tab 2 tablet. On the OV one of the built in programs when I hit the app drawer is Calendar, a very simple app that shows a monthly calendar.
The tablet doesn't show Calendar when I view the totality of programs. My question is whether it is there under some other name?
If not is there an app that duplicates the V's built-in calendar? I know there are dozens of widgets available with bells/whistles/appointments/alarms etc. I'm not looking for that. Just want to be able to call up a monthly calendar from time to time when I'm on the tablet.
Thanks.
AFAIK, the Google Calender is a default part of the Android OS. I don't own a Tab2, but it is pre installed on the S2 and S3. You may be able to d/l it from the play store. There are also a ton of calender widgets available, many free. Once again, I don't know which work with the Tab, but you should find something acceptable. One thing to do? make sure that you're syncing calender data with you gmail account settings > accounts > choose your default google account.
I'm moving this to the Tab 2 section for better results. Best of luck to you!
On mine it is called S Planner, which is different type then the regular Google Calendar. I do have Google Calendar on my phone and it does sync with S Planner if I set up appointments or whatnot.
Thank you. Yes, my tablet has S Planner and it's just what I wanted.
I love when that happens!
