Root does not Auto Connect to Wifi ??
7500
Member
Hi i am on Galaxo 1.6.3 , its an amazing o.s btw , currently I am facing a little problem , my phone does not auto connect to my home wifi , I have to manually go into settings >> wifi settings >> and then select my wifi from there , since it requires time and effort I end up using my 3G network which is burning an hole in my pocket , so plz help me ASAP ,
thx.
well I have installed Wefi app , it has done the trick but at the cost of eating RAM, I hope there could be an better solution .
thx.
I had this same problem, and for me, the solution was a baseband update. I went to IK5 from II4, and voila, wifi auto-connect worked!
thx.
AFAIK 1.6.3.3 has a setting which has three option
1. Wifi never sleep when plugged
2. Never sleep
3. I dont rem'r but not necessary
So you can dig into wifi settings to find the same
No need for any app
Well personally I also use two widgets
1. WiFi on/Off - For switching on/off wifi
2. Wifi Reconnect - To remove from wifi sleep
