What Redundant piece of software/launcher you have running on your phone has absolutely nothing to do with the OP's question.
OP: Desktop Websites will be able to fit more in the view and still remain redable onteh Note 3 due to the larger screen.
Mobile websites, you may gain by being able to fit more text on a line but those sites generally aren't as flexible in terms of fitting much more on a screen since they're designed to be viewed with little to no horizontal panning.
