Does ps3 have dlna?
Does the ps3 have dlna and if it does how do i hook it up to my dhd?
Yes it does, and I'm using it right now!!!
I run a Linux system on my PC so use XBMC media centre to stream movies, music, pics, etc from my PC to my PS3 and my DHD!
Love it!!! :D
Love it!!! :D
im running linux mint 10 on one pc and backtrack 4 on the other. Can you tell me how you get XBMC media centre please? Cant find it in the software manager
cheers
cheers
I'm running Ubuntu, so I'm guessing it's similar. Here's the guide and the link:
Installing XBMC Ubuntu 9.10 Karmic or higher
If you are using Ubuntu 9.10 or higher, you have the option of a more streamlined install. Load the terminal window and issue the following:
sudo apt-get install python-software-properties pkg-config
sudo add-apt-repository ppa:team-xbmc
sudo apt-get update
sudo apt-get install xbmc xbmc-standalone
sudo apt-get update
HOW-TO install XBMC for Linux on Ubuntu, a Step-by-Step Guide - XBMC
Good Luck! :)
sudo apt-get update
sudo apt-get update
Good Luck! :)
cheers for that. downloaded it last night. pretty straight forward. havent got my dhd or ps3 to find it yet though. ive 'shared' a folder on my desktop with videos inside it and then searched on my ps3 for servers but nothing is found.
ill have another go later on
In order to setup, you just need to follow this path:
Open XBMC > Videos> Add Source> Browse
Find the folder with the videos in and then press ok.
Now Everytime that XBMC is open and your PS3 is on at the same time, they will recognise eachother and if your DHD is on the same network it will see it too if you're using something like Twonky.
:cool:
