Does Ringcontrol work on Droid?
anderkoo
Ringcontrol sounds like a neat app that sets the ringer mode depending on whether the phone is set face-up or face-down. Since it's tied to the hardware, I wanted to see if any Droid users have tried it and have found it to work before I plop my hard-earned $.99 on it.
Anyone?
I can't give you a definitive answer but, I think it should work. I have used a bunch of apps that used accelerometer and none have had a problem.
Anyone?
If you uninstall the software within the first 24hrs of downloading it you get a full refund. Purchase the software and if it doesn't work you loose nothing.
