funkylogik
share the love peeps ;)
Just wondering coz I can't seem to find one.
If so, what's it called?
Cheers
Cheers
Yeah that's all I could find (and I have it disabled)Think Google Music is the stock player... or was when i was back on stock
May enable it some day and give it a shot (being a Google fanboy lol).Big fan of Google music, been using it since it came out.
On some,if not most devices,it does,but,you can use any equalizer you wish & the GPS Music app will use it.May enable it some day and give it a shot (being a Google fanboy lol).
Does it have EQ?
Apollo is available on Play Store. I've been using a simple material design app called Orpheus. It doesn't have EQ but I use Viper as it blows away everything else for audio processing. MaxAudio is uninstalled
I have one issue. I got my Media Storage corrupted and couldn't copy files to my device via MTP so I cleared it data and then used a program to rescan the sdcard. This was fine except it didn't have my ringtones (from /system) anymore. Easy fix I thought. I copied the media folder deleted it then copied it back. Done. Ringtones and Alarms back on the list... and my media player plays them as audio files in shuffle play. Doh! Anyone know how to fix this? Reflashing wont
Two problemsPut a .nomedia in your ringtones directory, then the media scanner and music players will ignore them.
