skeeter50187
jus wanna kno...
It has a notification LED.
I would think so, since S3 can do multi colors without an app.I have heard it has a smaller and lower powered light which doesn't give as strong an LED as the S3.
Further I also heard of a possibility in it having multi colour by default without additional software support such as GoSMS.
Can't speak to the strength of the led.
Ah, well if your asking if the S3 native apps use the function, no they don't.I didn't think the S3's SMS App did multi colour notification, hence why some use GoSMS with it's individual colour LED's.
Why does it matter? #justcurious
There's a better one here ~ Galaxy S4 In-Depth First Impressions *Samsung Unpacked 2013* - YouTube
Look especially at 1:28 where the reviewer gives a meaningfull explanation of all the radios at the top of the handset and at 2:50 they then show and mention the RGB LED.
I still though have not found anything further on whether or not this LED can do separate colours for SMS like GoSMS does.
I know believe my source to be incorrect.
The GS3 LED light was able to change colors. I don't see any reason why this should be different.
Thanks... I'm happy it has an LED Notification.
What I'm looking for is if anyone has found any specs on the LED?
download NOLED.way better. at a quick glance at your screen you can see a pic of every notice you have, from any app you have.
