Look for "Time without signal" and it should be less than 10 percent, if any at all. If you don't see this, it's 0. If it is over 10 percent theres a problem. It could be bad signal, poor signal+hand covering the bottom ( Don't do this...that's where the antenna is! ), or somehow you got into GSM auto instead of CDMA auto ( In this case, you'll probably see TWOS in the 40-50% range. )
