Root does this work for the motion
If you're on your phone click the link with metroweb, chrome did the same thing as you said. It will play a video with metro web. :thumbup:
Sent from my typewriter.
O ok. Dont have metro Web anymore. Is just showing the animation? Our is it instructionsm
I did not create this I just figured a way to use it with out recovery Since we dont have recovery we have to do it manually, so im posting up my framework with the jb animation/ transitions already to use, after downloading the file im going to post you need to open up the Zip file and take out the framework.apk from its folder, once thats done use root explorer to navigate were ever you left the framework at, copy and paste in your system/ framework your phone should reboot. Thats it :-)
Thx.... to ubercharrge for finding this for us thx bro...
JB anim
Do at your own risk
Not much of a difference, but cool nonetheless. :)
I made a copy of my original framework so I can paste it back in if I notice things working wonky.
I decompile framework-res.apk with multi, replace anim with whatever transitions I feel like at the time, and compile-push. I guess Metamorph would be easier :)
hey I was just wondering if anybody knows if the OTG cables work for this phone. I bought 1 and I don't really know about them it was just really cheap. so if anybody does happen to know if this works or if you have to configure it or not let me know
