Does TM Tab have a activiation or need to be unlocked?
katinsc
For those who returned their Verizon for the TM Tab...
I will need to buy a TM from online. I have a VZW mifi,
With the TM Tab is there an activiation screen? Or does it need to be unlocked the way my VZW did? How do I buy pass the activation screen?
So until I set up a plan with TM, i won't have IM capability, anything else I should consider? I guess the data plan I have with my VZW Mifi will not work with the TM Tab, right?
My T-Mob Tab came with a pre-installed Sim card. when I turned it on it already had a 3g connection. the 3g connection basically lasted for an hour then it started taking me to a t-mob prepay site. you don't have to activate the sim and you should be able to use your Mifi in wifi mode. I am currently using my VZW D1 and Android WIFI Tether to access the net.
