does yahoo mail work on v3?
I've been trying to get yahoo mail working on v3 and have been unsuccessful. I know it works onthe ota because my girlfremd has it..so does it work on the v3 leak?
it does. I have the leak v3. I was having trouble also and I did a search on here and I got the info. you have to change it from pop to imap I think and change server port to 143. do a search to double check. I am also pretty sure you need to have wifi off.
Sent from my Eris using Tapatalk
I tried searching and couldn't really find anything...then again I'm not exactly sure on how to search, do I just use the bar in the upper right corner? If so I couldn't find anything on it.
I think so. I'd look but the wife is on the computer. in the mail settings after you in put your address and such make sure its imap and not pop
this is what mine says
imap server
imap.mail.yahoo.com
security type
none
server port
143
