The device can heat up with use, it's completely normal, it's not something to be concerned with.
And how many of them had a CDMA modem, an LTE modem and a dual core 1Ghz processor to power at the same time?A handful of reviews also note that their Bionics became quite warm after some use so it's normal.
My phone gets SUPER HOT and with the extended battery fullu charged died overnight JUST SITTING ON THE DRESSER NOY BEING USED! What's up with that??/
Do it again and check what's eating your battery.
I installed juice defender, hopefully that helps. It was at 100% battery at 11pm and this morning when I woke up at 7am it was "in the orange".![]()
that's because you have apps running constantly in the background. you should open you task manager and see what is running...I installed juice defender, hopefully that helps. It was at 100% battery at 11pm and this morning when I woke up at 7am it was "in the orange".![]()
Gets a little warm with the shell/holster case but nothing unexpected. My DX got warm with heavy use but nothing serious.Just curious if the Bionic gets hotter with the plastic cover/holster combo on? Mine has NO air holes.
Thoughts?
